[petsc-dev] No rule to make target 'mfem-build'
Hapla Vaclav vaclav.hapla at erdw.ethz.ch
Sat Dec 1 09:04:12 CST 2018
Thanks, you're right.
However,
$ make reconfigure
             Configuring PETSc to compile on your system
                          ***** WARNING: MAKEFLAGS (set to ) found in environment variables - ignoring
                        use ./configure MAKEFLAGS=$MAKEFLAGS if you really want to use that value ******            ===============================================================================
although I have no such variable set in my shell.
Vaclav
> 1. 12. 2018 v 15:36, Stefano Zampini <stefano.zampini at gmail.com>:
> I have added a new package that gets built after petsc. You have to run
> make reconfigure
> Il giorno Sab 1 Dic 2018, 16:52 Hapla Vaclav <vaclav.hapla at erdw.ethz.ch> ha scritto:
> Hi Stefano
> After pulling latest master, I get the following at the end of make output:
> make[1]: *** No rule to make target 'mfem-build', needed by 'all-gnumake-local'.  Stop.
> make[1]: Leaving directory '/scratch/petsc-dev-1'
> Now to check if the libraries are working do:
> make PETSC_DIR=/scratch/petsc-dev-1 PETSC_ARCH=arch-linux-gcc check
> Do you think you could remove that line for non-mfem builds? I think it looks like an error for a user.
> Vaclav
