[petsc-dev] PETSc blame digest (next) 2018-04-23
Smith, Barry F. bsmith at mcs.anl.gov
Mon Apr 23 11:07:48 CDT 2018
   Dang, I fixed this yesterday but then forgot to merge the branch barry/bugfix-petscformatconvert into next for testing.
   Barry
> On Apr 23, 2018, at 7:28 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>  The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/14416c0
> Insure PetscPrintf(), PetscVPrintfDefault(), PetscSynchronizedPrintf(), PetscSynchronizedFPrintf(), and PetscViewerASCIIPrintf() handle printed strings longer than the default buffer size of 8*1024 bytes properly
>  src/sys/classes/viewer/impls/ascii/filev.c:991
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-freebsd-cxx-cmplx-pkgs-dbg_wii.log]
>      /usr/home/balay/petsc.next/src/sys/classes/viewer/impls/ascii/filev.c:991:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-linux-pkgs-cxx-mlib_el6.log]
>      /home/sandbox/petsc/petsc.next-3/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-linux-cmplx-gcov_steamroller.log]
>      /sandbox/petsc/petsc.next-2/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-linux-xsdk-dbg_cg.log]
>      /sandbox/petsc/petsc.next/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-linux-opt-cxx-quad_grind.log]
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-freebsd-cxx-pkgs-opt_wii.log]
>      /usr/home/balay/petsc.next-2/src/sys/classes/viewer/impls/ascii/filev.c:991:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
>  src/sys/fileio/mprint.c:785
>    [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_arch-linux-matlab-ilp64-gcov_thrash.log]
>      /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:785:17: error: 'len' undeclared (first use in this function)
>      /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:785:12: warning: unused variable 'buff' [-Wunused-variable]
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/df41390
> fixed problem with Matlab being nonresponsive when run with -nodisplay and built with MPI
>  src/sys/fileio/mprint.c:788
>      /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:788:20: error: 'buf' undeclared (first use in this function)
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
