[petsc-dev] [petsc-users] PetscPrintf
Smith, Barry F. bsmith at mcs.anl.gov
Thu Apr 12 09:48:18 CDT 2018
> On Apr 12, 2018, at 3:59 AM, Patrick Sanan <patrick.sanan at gmail.com> wrote:
> I also happened to stumble across this yesterday. Is the length restriction for the default printer (l assume from the array of 8*1024 chars in PetscVFPrintfDefault() ) intended behavior to be documented, or a bug to be fixed?
     You could call it either. My problems are
1) that given a format string I don't know in advance how much work space is needed so cannot accurately malloc, for sure, enough space
2) since this can be called in an error handler I really don't want it calling malloc().
   Hence it lives in this limbo. I don't even know a way to add a good error checking that detects if the buffer is long enough. All in all it is bad ugly code, any suggestions on improvements would be appreciated.
   Barry
> 2018-04-12 2:16 GMT+02:00 Rongliang Chen <rongliang.chan at gmail.com>:
> Thanks Barry. I found petsc-3.6 and older versions did not have this restriction.
> Best,
> Rongliang
> On 04/12/2018 07:22 AM, Smith, Barry F. wrote:
>    Yes, PetscPrintf() and related functions have a maximum string length of about 8000 characters.
>     Barry
> On Apr 11, 2018, at 6:17 PM, Rongliang Chen <rongliang.chan at gmail.com> wrote:
> Dear All,
> When I tried to print a long string using PetscPrintf() I found that it truncated the string. Attached is a simple example for this (run with single processor). I used PetscPrintf() and printf() to print the same string and the printf() seems OK. I am using petsc-3.8.4.
> Best,
> Rongliang
> <ex111.c>
