[petsc-dev] Fix VecScatterDestroy() and issue with VecScatterCreateEmpty()
Lisandro Dalcin dalcinl at gmail.com
Mon Apr 2 03:38:02 CDT 2018
While updating petsc4py for the VecScatter changes, I found two issues:
1) VecScatterDestroy needs a couple fixes:
https://bitbucket.org/petsc/petsc/pull-requests/919/fix-vecscatterdestroy/diff
Satish, this PR should be safe to go to master ASAP before release.
2) We have VecScatterCreateEmpty(). This one does not set a type on
the scatter context. Then, VecScatterCopy() fails afterwards. As
VecScatterCreateEmpty() is not used AT ALL anywhere else int the
codebase (not even in tests), I'm not sure what to do with it. In the
mean time, I'm just removing the test I just wrote in petsc4py.
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
