[petsc-dev] DMPlexCreateMedFromFile broken
Vaclav Hapla vaclav.hapla at erdw.ethz.ch
Thu Nov 2 11:08:07 CDT 2017
It seems that DMPlexCreateMedFromFile leaves out some mesh elements. I found it out when investigating why ParMetis redistribution crashes.
I attach the datafile $PETSC_DIR/share/petsc/datafiles/meshes/blockcylinder-50.exo converted to GMSH and MED format.
The conversion EXO to GMSH was done by meshio (github.com/nschloe/meshio), and GMSH to MED by GMSH itself.
I did:
cd $PETSC_DIR/src/dm/impls/plex/examples/tutorials
make ex5
FILE=blockcylinder-50.exo && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5 && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
FILE=blockcylinder-50.msh && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5 && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
FILE=blockcylinder-50.med && ./ex5 -filename $FILE -dm_view hdf5:$FILE.h5 && $PETSC_DIR/bin/petsc_gen_xdmf.py $FILE.h5
While the output from blockcylinder-50.exo and blockcylinder-50.msh looks OK, that from blockcylinder-50.med is corrupted.
I also attach my HDF5/XDMF outputs and screenshots from ParaView.
Vaclav
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171102/1aad1998/attachment-0003.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171102/1aad1998/attachment-0004.zip>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171102/1aad1998/attachment-0005.zip>
