[petsc-dev] MatISGetLocalMat: need to MatDestroy the returned local matrice ?
Jed Brown jed at jedbrown.org
Fri May 19 19:13:49 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Sure, I am not advocating not having restores but if we do have
>   things without restores a different name makes it clearer that it is
>   providing a different kind of access.
We should fix the code to use Restore, not work around it by creating
new terminology.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170519/fed3bc7f/attachment.sig>
