[petsc-dev] MatISGetLocalMat: need to MatDestroy the returned local matrice ?
Jed Brown jed at jedbrown.org
Fri May 19 18:58:59 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>    Jed,
>      Should this utilize the Get/Restore paradigm?
>      If not should the name be different to prevent confusion? Currently we have
>   XXXCreate -->  user needs to call a destroy
>    XXXXGetYYY  --> user needs to call a restore (but not always?)
>    Could we introduce say
>     XXXAccessYYY   --> user does not call destroy or restore ?
Even VecGetArrayRead requires matching Restore.  Light access is less
safe and gives the library less opportunity for strictness to catch
bugs.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170519/e13068f4/attachment.sig>
