[petsc-dev] MatCreateSubMatrices in parallel with n=0 on a process causes memory leak
Brad Aagaard baagaard at usgs.gov
Mon Mar 27 12:39:52 CDT 2017
PETSc developers,
In PyLith we call MatCreateSubMatrices() and MatDestroyMatrices() with
potentially different numbers of submatrices on each process. If each
process has a nonzero number of submatrices things appear to be working
fine. If a process has zero submatrices, I am getting a memory leak on
that process (as reported by -malloc_dump). I did not get this behavior
with PETSc 3.7.2 and earlier with MatGetSubMatrices() and
MatDestroyMatrices().
Do I need to do something special when calling MatCreateSubMatrices() or
MatDestroyMatrices() when the number of submatrices on a process is zero?
The log with the petsc log summary and malloc dump output is attached.
Brad
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170327/eb006dc2/attachment.bin>
