[petsc-dev] MatMatMult crashes with MATMPIAIJ using one processor
Hong hzhang at mcs.anl.gov
Fri Mar 17 10:58:42 CDT 2017
Ce Qin:
This is fixed in branch hzhang/matmatops_mpiaij4np1.
I consider it as a new feature - support mpiaij for np=1, not a bugfix.
Once it passes our regression tests, I'll merge it to petsc master branch.
You may test it. Let us know you see any problem.
Thanks for reporting it.
Hong
Dear all,
> I encountered a problem that MatMatMult crashes using only one processor.
> The matrix is MATMPIAIJ. I am using the master branch. The same program can
> run in parallel without problem.
> Valgrind gives the following stack trace:
> ==5543== Invalid read of size 8
> ==5543==    at 0xDC094CE: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:4509)
> ==5543==    by 0xDC3FB95: MatMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable
> (mpimatmatmult.c:218)
> ==5543==    by 0xDC45193: MatMatMult_MPIAIJ_MPIAIJ (mpimatmatmult.c:61)
> ==5543==    by 0xD9C657D: MatMatMult (matrix.c:9450)
> ==5543==
> ==5543== Invalid read of size 4
> ==5543==    at 0xDC094D7: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:4510)
> ==5543==
> ==5543==    at 0xDC0793B: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:4513)
> ==5543==    at 0xDC0794E: MatGetBrowsOfAoCols_MPIAIJ (mpiaij.c:4520)
> This problem may be related to this thread http://lists.mcs.anl.gov/
> pipermail/petsc-users/2014-September/022864.html. If you need an
> example that reproduces this problem, please let me know.
> Best,
> Ce Qin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170317/bfbdffe2/attachment.html>
