[petsc-dev] fork for programming models debate (was "Using multiple mallocs with PETSc")
Jed Brown jed at jedbrown.org
Thu Mar 16 07:30:13 CDT 2017
Jeff Hammond <jeff.science at gmail.com> writes:
>> >> > OpenMP did not prevent OpenCL,
>> >> This programming model isn't really intended for architectures with
>> >> persistent caches.
>> > It's not clear to me how much this should matter in a good
>> implementation.
>> > The lack of implementation effort for OpenCL on cache-coherent CPU
>> > architectures appears to be a more significant issue.
>> How do you keep data resident in cache between kernel launches?
> Not do stuff that causes it to be evicted.
Okay, but the OpenCL model encourages a granularity that would cause
eviction, and is over-synchronizing (for many tasks) if you attempt to
maintain cache locality.
>> >> > C11, C++11
>> >> These are basically pthreads, which predates OpenMP.
>> > I'm not sure why it matters which one came first.  POSIX standardized
>> > threads in 1995, while OpenMP was first standardized in 1997.  However,
>> the
>> > first serious Pthreads implementation in Linux was in 2003.
>> And the first serious OpenMP on OS X was when?
> When was the first serious implementation of MPI-3 shared memory windows on
> OSX? That is your alternative to OpenMP for shared memory.
shm_open has been there, and MPI without shared memory is not bad for
many purposes.
> I think it is rather pathetic to use Apple's compiler support as an
> argument against the OpenMP programming model.
It's just evidence that portability is relevant; OpenMP is not
ubiquitous.
> In any case, MPI doesn't run on any GPU hardware, nor any FPGA, nor DSP.
> OpenMP supports at least two of these.
"Supports" does not imply it is a desirable programming model.
>> > OpenMP standardized the best practices identified in Kuck, SGI and
>> > Cray directives, just like POSIX presumably standardized best
>> > practices in OS threads from various Unix implementations.
>> > C++11 and beyond have concurrency features beyond just threads.  You
>> > probably hate all of them because they are C++, and in any case I won't
>> > argue, because I don't see anything that's implemented better
>> >> > or Fortran 2008
>> >> A different language and doesn't play well with others.
>> > Sure, but you could use Fortran 2003 features to interoperate between C
>> and
>> > Fortran if you wanted to leverage Fortran 2008 concurrency features in an
>> > ISO-compliant way.  I'm not suggesting you want to do this, but I dispute
>> > the suggestion that Fortran does not play nice with C.
>> I think the above qualifies as not playing nicely in this context.
> ISO-defined interoperability is not playing nice?
Write an extensible C library that uses Fortran 2008 parallelism and get
back to me.  My opinion now is that the impedance mismatch would be
overwhelming, ignoring for the moment that I think Fortran 2008's
specification is terribly inadequate and misdesigned.
>> > Fortran coarrays images are OS processes in every implementation I know,
>> > although the standard does not explicitly require this implementation.
>> The
>> > situation is identical to that of MPI, although there are actually MPI
>> > implementations based upon OS threads rather than OS processes (and they
>> > require compiler or OS magic to deal with non-heap data).
>> > Both of the widely available Fortran coarray implementations use MPI-3
>> RMA
>> > under the hood and all of the ones I know about define an image to be an
>> OS
>> > process.
>> Are you trying to sell PETSc on MPI?
> No. I am countering your suggestion that they don't play nice.
They don't, and Fortran 2008's constructs suck.  CAF 2.0 acknowledges
some of those deficiencies.
>> >> > from introducing parallelism. Not sure if your comment was meant to be
>> >> > serious,
>> >> Partially.  It was just enough to give the appearance of a solution
>> >> while not really being a solution.
>> > It still isn't clear what you actually want.  You appear to reject every
>> > standard API for enabling explicit vectorization for CPU execution
>> > (Fortran, OpenMP, OpenCL), which suggests that (1) you do not believe in
>> > vectorization, (2) you think that autovectorizing compilers are
>> sufficient,
>> > (3) you think vector code is necessarily a non-portable software
>> construct,
>> > or (4) you do not think vectorization is relevant to PETSc.
>> OpenMP is strictly about vectorization with nothing to do with threads
>> and MPI is sufficient?  I don't have a problem with that, but will
>> probably stick to attributes and intrinsics instead of omp simd, at
>> least until it matures and demonstrates feature parity.
> Is MPI strictly about collectives?
My point is that I don't mind OpenMP as a portable annotation system for
SIMD, but I don't think it's a good foundation for using multiple cores
and I don't think it obviates the need for non-portable constructs.
>> Have you tried writing a BLIS microkernel using omp simd?  Is it any
>> good?
> Have you tried writing MPI send-recv using TCP/IP?
Seems unrelated.  If OpenMP SIMD is a viable portable alternative to
something non-portable (assembly or intrinsics) then it must be able to
achieve a substantial fraction of the non-portable case.
> You appear disinterested in trying to come up with constructive ideas. I
> don't see any value in continuing this conversation.
To be honest, I don't know why you started this thread if not to
proselytize OpenMP, which I don't think is a good abstraction for shared
memory parallelism.  Last time we talked in person, you seemed to agree
on that point.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170316/939a9683/attachment.sig>
