[petsc-dev] fork for programming models debate (was "Using multiple mallocs with PETSc")
Wed Mar 15 02:11:53 CDT 2017
On Tue, Mar 14, 2017 at 10:52 PM, Jed Brown <jed at jedbrown.org> wrote:
> Jeff Hammond <jeff.science at gmail.com> writes:
> >> > OpenMP did not prevent OpenCL,
> >> This programming model isn't really intended for architectures with
> >> persistent caches.
> > It's not clear to me how much this should matter in a good
> implementation.
> > The lack of implementation effort for OpenCL on cache-coherent CPU
> > architectures appears to be a more significant issue.
> How do you keep data resident in cache between kernel launches?
> >> > C11, C++11
> >> These are basically pthreads, which predates OpenMP.
> > I'm not sure why it matters which one came first.  POSIX standardized
> > threads in 1995, while OpenMP was first standardized in 1997.  However,
> the
> > first serious Pthreads implementation in Linux was in 2003.
> And the first serious OpenMP on OS X was when?
> > OpenMP standardized the best practices identified in Kuck, SGI and
> > Cray directives, just like POSIX presumably standardized best
> > practices in OS threads from various Unix implementations.
> > C++11 and beyond have concurrency features beyond just threads.  You
> > probably hate all of them because they are C++, and in any case I won't
> > argue, because I don't see anything that's implemented better
> >> > or Fortran 2008
> >> A different language and doesn't play well with others.
> > Sure, but you could use Fortran 2003 features to interoperate between C
> and
> > Fortran if you wanted to leverage Fortran 2008 concurrency features in an
> > ISO-compliant way.  I'm not suggesting you want to do this, but I dispute
> > the suggestion that Fortran does not play nice with C.
> I think the above qualifies as not playing nicely in this context.
> > Fortran coarrays images are OS processes in every implementation I know,
> > although the standard does not explicitly require this implementation.
> The
> > situation is identical to that of MPI, although there are actually MPI
> > implementations based upon OS threads rather than OS processes (and they
> > require compiler or OS magic to deal with non-heap data).
> > Both of the widely available Fortran coarray implementations use MPI-3
> RMA
> > under the hood and all of the ones I know about define an image to be an
> OS
> > process.
> Are you trying to sell PETSc on MPI?
> >> > from introducing parallelism. Not sure if your comment was meant to be
> >> > serious,
> >> Partially.  It was just enough to give the appearance of a solution
> >> while not really being a solution.
> > It still isn't clear what you actually want.  You appear to reject every
> > standard API for enabling explicit vectorization for CPU execution
> > (Fortran, OpenMP, OpenCL), which suggests that (1) you do not believe in
> > vectorization, (2) you think that autovectorizing compilers are
> sufficient,
> > (3) you think vector code is necessarily a non-portable software
> construct,
> > or (4) you do not think vectorization is relevant to PETSc.
> OpenMP is strictly about vectorization with nothing to do with threads
> and MPI is sufficient?  I don't have a problem with that, but will
> probably stick to attributes and intrinsics instead of omp simd, at
1) and 4) are clearly wrong. After decades of work, 2) seems practically
wrong.
This looks like a 3) answer to me, and its hard to argue. OpenCL could have
been a nice
way to get arch-independent vectorization, but the implementations suck
badly.
> least until it matures and demonstrates feature parity.
> Have you tried writing a BLIS microkernel using omp simd?  Is it any
> good?
Yep.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170315/52db3282/attachment.html>
