[petsc-dev] building on KNL
Sat Mar 11 10:22:02 CST 2017
Looks like a module problem
Executing: cc -c -o /tmp/petsc-7rDzhd/config.setCompilers/conftest.o
-I/tmp/petsc-7rDzhd/config.setCompilers
/tmp/petsc-7rDzhd/config.setCompilers/conftest.c
Possible ERROR while running compiler: exit code 256
stderr:
Error invoking pkg-config!
Package cray-udreg was not found in the pkg-config search path.
Perhaps you should add the directory containing `cray-udreg.pc'
to the PKG_CONFIG_PATH environment variable
Package 'cray-udreg', required by 'mpich', not found
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
              Popping language C
          Error testing C compiler: Cannot compile C with cc.
            Deleting "CC"
   Matt
On Sat, Mar 11, 2017 at 8:43 AM, Mark Adams <mfadams at lbl.gov> wrote:
> I have been using Cori/KNL with Intel MPI and want to move to cray-mpi
> and am having an error with cc.
> 06:42 1 cori06 maint= ~/petsc_install/petsc$ cc --version
> icc (ICC) 17.0.1 20161005
> Copyright (C) 1985-2016 Intel Corporation.  All rights reserved.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170311/1e0274b4/attachment.html>
