[petsc-dev] Using multiple mallocs with PETSc
Jed Brown jed at jedbrown.org
Fri Mar 10 14:42:04 CST 2017
Jeff Hammond <jeff.science at gmail.com> writes:
> My intuition is that any HPC code that benefits from mapping the zero page
> vs memset is doing something wrong.
The relevant issue is the interface, from
  a = malloc(size);
  // need to fault the memory using first-touch
  #pragma omp parallel
    // memset my part
    // Use a[] knowing it starts zeroed
versus
  a = calloc(size,1);
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170310/32c17acd/attachment.sig>
