[petsc-dev] Using multiple mallocs with PETSc
Fri Mar 10 13:52:45 CST 2017
> On Mar 10, 2017, at 12:04 AM, Richard Mills <richardtmills at gmail.com> wrote:
> On Thu, Mar 9, 2017 at 9:05 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
> On Thu, Mar 9, 2017 at 8:08 PM, Richard Mills <richardtmills at gmail.com> wrote:
> On Thu, Mar 9, 2017 at 7:45 PM, Jeff Hammond <jeff.science at gmail.com> wrote:
> I started to play with memkind last summer. At that time, there were plenty of sayings online like this:
> "the hbwmalloc interface is stable but memkind interface is only partially stable."
> If you want the most stable interface, just use libnuma.  It took me less than a day to reimplement hbwmalloc.h on top of libnuma and dlmalloc (https://github.com/jeffhammond/myhbwmalloc).  Note that myhbwmalloc was an education exercise, not software that I actually think anyone should use.  It is intentionally brittle (fast or fail - nothing in between).
> One consequence of using libnuma to manage MCDRAM is that one can call numa_move_pages, which Jed has asserted is the single most important function call in the history of memory management ;-)
> I think you can also move pages allocated by memkind around by calling numa_move_pages, actually, but this breaks the heap partitioning that memkind does.
> I actually question whether we even need a heap manager for things like big arrays inside of Vec objects.  It should be fine to just call mmap() directly for those.  These will tend to be big things that don't get allocated/deallocated too frequently, so it probably won't matter that an expensive system call is required.
> I think this is a terrible idea.  What happens when a user runs a tiny debug job that takes 1000x longer than it should because every object ctor/dtor requires a system call?
> I'm not necessarily saying it's a great idea, either.  But if we are seriously wanting to do things like migrating our own pages around (expensive system call required), then doing our own mmap() and mbind() calls may make sense.  You'd only want to do this for large and long-lived objects (like a Jacobian matrix) that you expect may need to reside in the high-bandwidth memory.  I did a lot of low-level systems stuff for my dissertation, working on out-of-core calculations, and I wrote a middleware library that handled memory placement and did all of the memory allocation directly with mmap() calls.  For long-lived linear algebra objects, the overhead for that was negligible.
> Personally, I think that memkind is something we should support it in PETSc.
   Yes, the question is how do we "support it"? Do we have a PETSc malloc API and then it can direct the calls down to "classic malloc(), memkind, .....? At this time I think saying the PETSc malloc API is "just" the memkind API would be a mistake.  If we have a PETSc malloc API* what is crucial to have in the PETSc malloc API? And what should the API look like. Three things that could/should possibly be exposed are: "kind of memory", alignment (if doing SIMD this might/is important), page size (these three things are exposed by memkind/hbm_xxx().
* PETSc currently does have a Petsc malloc API but it has always been kept exceedingly limited, so the question is more if we extend it and how we extend it.
>  That doesn't mean it's the ideal solution, but it has utility now.  We can certainly support something else when something better arrives.
  Disappointing on my Mac.
WARNING: Could not locate OpenMP support. This warning can also occur if compiler already supports OpenMP
checking omp.h usability... no
checking omp.h presence... no
checking for omp.h... no
omp.h is required for this library
   Now I have read through all the old email from Jed to understand why he hates memkind so much.
  Barry
> --Richard
> Jeff
> --Richard
> Jeff
> Perhaps I should try memkind calls since they may become much better.
> Hong (Mr.)
> Jeff Hammond
> http://jeffhammond.github.io/
> Jeff Hammond
