[petsc-dev] Using multiple mallocs with PETSc
Jeff Hammond jeff.science at gmail.com
Thu Mar 9 21:45:56 CST 2017
> I started to play with memkind last summer. At that time, there were
> plenty of sayings online like this:
> "the *hbwmalloc* interface is stable but *memkind* interface is only
> partially stable."
If you want the most stable interface, just use libnuma.  It took me less
than a day to reimplement hbwmalloc.h on top of libnuma and dlmalloc (
https://github.com/jeffhammond/myhbwmalloc).  Note that myhbwmalloc was an
education exercise, not software that I actually think anyone should use.
It is intentionally brittle (fast or fail - nothing in between).
One consequence of using libnuma to manage MCDRAM is that one can call
numa_move_pages, which Jed has asserted is the single most important
function call in the history of memory management ;-)
Jeff
> Perhaps I should try memkind calls since they may become much better.
> Hong (Mr.)
Jeff Hammond
http://jeffhammond.github.io/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170309/8cfb4901/attachment.html>
