[petsc-dev] VecScatter scaling problem on KNL
Wed Mar 8 18:29:37 CST 2017
  Mark,
   Are you getting this with PETSc 3.7.5 ?  Is the code valgrinded?
> On Mar 8, 2017, at 6:27 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Wed, Mar 8, 2017 at 4:57 PM, Richard Mills <richardtmills at gmail.com> wrote:
>> Hi Mark,
>> Is your application threaded?  I seem to recall having seen these "Logging
>> event had unbalanced begin/end pairs" with threaded codes that call PETSc.
> It is OMP threaded, but it should certainly not call PETSc inside of a
> thread loop... but this does look like something that threading could
> cause.
>> --Richard
>> On Wed, Mar 8, 2017 at 1:33 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Our code is having scaling problems on KNL (Cori), when we get up to
>>> about 1K sockets.
>>> We have isolated the problem to a certain VecScatter. This code stores
>>> the data redundantly. Scattering into the solver is just a local copy,
>>> but scattering out requires that each process send all of its data to
>>> every other process. It is this second one that is not scaling well.
>>> I wish I had more data, but this is urgent, jobs are in the queue, but
>>> this is all I have. Any recommendation for parameters that we might
>>> test while we get more data?
>>> Also, we got this error with -log_view.
>>> I've updated their PETSc with maint and we are waiting for it to run
>>> again. Apparently this was not on the first time step, so the code
>>> seems to have run for a while with what looks to me like a logic bug.
>>> Thanks,
>>> Mark
>>> [4098]PETSC ERROR: --------------------- Error Message
>>> [4098]PETSC ERROR: Object is in wrong state
>>> [4098]PETSC ERROR: Logging event had unbalanced begin/end pairs
>>> [4098]PETSC ERROR: See
>>> http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>> shooting.
>>> [4098]PETSC ERROR: Petsc Release Version 3.6.3, unknown
>>> [4098]PETSC ERROR: /global/cscratch1/sd/worleyph/XGC1_KNL/xgc2 on a
>>> v3.6.3-arch-knl-opt64-intel named nid05668 by worleyph Mon Mar  6
>>> 11:33:19 2017
>>> [4098]PETSC ERROR: Configure options COPTFLAGS="-g -O3 -fp-model fast
>>> -xMIC-AVX512 -DX2_HAVE_INTEL" CXXOPTFLAGS="-g -O3 -fp-model fast
>>> -xMIC-AVX512\
>>> -DX2_HAVE_INTEL" FOPTFLAGS="-g -O3 -fp-model fast -xMIC-AVX512
>>> -DX2_HAVE_INTEL" --download-metis=1 --download-parmetis=1
>>> --with-blas-lapack-dir=/g\
>>> lobal/common/cori/software/intel/compilers_and_libraries_2017.0.098/linux/mkl
>>> --with-cc=cc --with-cxx=cc --with-debugging=0 --with-fc=ftn --with-mp\
>>> iexec=srun --with-batch=0 --with-memalign=64 --with-64-bit-indices
>>> --known-mpi-shared-libraries=1 PETSC_ARCH=v3.6.3-arch-knl-opt64-intel
>>> --with-ope\
>>> nmp=1 PETSC_DIR=/global/homes/t/tkoskela/git/petsc
>>> [4098]PETSC ERROR: #1 PetscLogEventEndDefault() line 696 in
>>> /global/u2/t/tkoskela/git/petsc/src/sys/logging/utils/eventlog.c
>>> [4098]PETSC ERROR: #2 VecSet() line 577 in
>>> /global/u2/t/tkoskela/git/petsc/src/vec/vec/interface/rvector.c
>>> [4098]PETSC ERROR: #3 VecCreate_Seq() line 44 in
>>> /global/u2/t/tkoskela/git/petsc/src/vec/vec/impls/seq/bvec3.c
>>> [4098]PETSC ERROR: #4 VecSetType() line 53 in
>>> /global/u2/t/tkoskela/git/petsc/src/vec/vec/interface/vecreg.c
>>> [4098]PETSC ERROR: #5 VecDuplicate_Seq() line 786 in
>>> /global/u2/t/tkoskela/git/petsc/src/vec/vec/impls/seq/bvec2.c
>>> [4098]PETSC ERROR: #6 VecDuplicate() line 399 in
>>> /global/u2/t/tkoskela/git/petsc/src/vec/vec/interface/vector.c
>>> [4098]PETSC ERROR: #7 VecDuplicateVecs_Default() line 840 in
>>> [4098]PETSC ERROR: #8 VecDuplicateVecs() line 473 in
