[petsc-dev] snes/ex56 target is gone
Jed Brown jed at jedbrown.org
Wed Jun 28 15:48:02 CDT 2017
Barry Smith <bsmith at mcs.anl.gov> writes:
>>>   Jed,
>>>    Aside from its name and location this is a very useful thing. Should it be in $PETSC_DIR/lib/petsc/conf/ ? since it cannot stay in $PETSC_DIR for --prefix installs?
>> I guess that's a reasonable location.  The file isn't platform-dependent
>> so it could go elsewhere.
> I don't understand. This directory is platform-independent. There is
> also a $PETSC_DIR/$PETSC_ARCH/lib/petsc/conf ; the two directories get
> merged in a prefix install.
What matters is the layout when you install.  The lib directory contains
platform-dependent stuff while other directories (include, share) should
not.  So this could go in share, but it is logically closer to the
platform-dependent stuff that has been going in lib so that's fine with
me.
>>  In that location, it should acquire a line
>> specifying PETSC_ARCH upon install.
>    You mean in a prefix install? There is no PETSC_ARCH in prefix installs.
If someone gives a path to a prefix install, I would say the behavior
should not depend on stale crud that might be floating in the PETSC_ARCH
environment variable.
>>  The only issue with the path is
>> that you're actually typing it on the command line, and that would be
>> a starter Makefile for anyone building a larger project.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170628/e110b96f/attachment.sig>
