[petsc-dev] Unable to access to MatSeqSBAIJGetArray_SeqSBAIJ from "outside" PETSc
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Fri Jan 6 14:46:05 CST 2017
we are trying to add a "petsc" developpement into our code but we need
to call MatSeqSBAIJGetArray_SeqSBAIJ for it.
Unlike MatSeqAIJGetArray_SeqAIJ which is accessible with either
MatSeqAIJGetArray
or
ierr =
PetscUseMethod(A,"MatSeqAIJGetArray_C",(Mat,PetscScalar**),(A,array));CHKERRQ(ierr);
there is no MatSeqSBAIJGetArray and we can't call it with
ierr =
PetscUseMethod(A,"MatSeqSBAIJGetArray_C",(Mat,PetscScalar**),(A,array));CHKERRQ(ierr);
since it isn't registered in MatCreate_SeqSBAIJ.
is it normal?
We can call MatSeqSBAIJGetArray_SeqSBAIJ directly, but the linker
complains about unresolved symbol because it is not exported global but
only local in our shared library:
nm /opt/petsc-3.7.2_debug_matmatmult_mpi/lib/libpetsc.so |grep
MatSeqSBAIJGetArray
00000000007f7b74 t MatSeqSBAIJGetArray_SeqSBAIJ
Is there any (nasty) way to override the shared library global/local
symbols attribute?
Eric
