[petsc-dev] need c++ expert help
    Matthew Knepley
    knepley at gmail.com
    Sun Dec 31 14:16:11 CST 2017
On Sun, Dec 31, 2017 at 3:14 PM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> > On Sun, Dec 31, 2017 at 1:55 PM, Jed Brown <jed at jedbrown.org> wrote:
> >> >> These look like linker errors and that build uses
> >> >> --with-cxxlib-autodetect=0.  We either need a rule to *link* C++
> using
> >> >> CXX (i.e., mpicxx) or add LIBS=-lstdc++.
> >> > I thought we were doing this (linking C++ mains with CXX).
> >> After compiling to the object file (ex3.o) we don't know what language
> >> main was written in, and this doesn't solve the actual problem that C++
> >> linking is required if any object (not just main) depends on C++.
> > My thinking here was the following:
> >   1) No C++ is allowed in PETSc, unless --with-clanguage=cxx, in which
> case
> > the linker is C++
> >   2) If C++ is in an external library, then that configure requires the
> C++
> > library
> >   3) The executable itself could be C++, in which case I proposed using
> the
> > C++ linker explicitly
> > About not knowing which objects come with C++ main: I thought we did.
> Don't
> > they go into a separate set?
> Right, we do have that information for tests.  Note that a single test
> executable can depend on multiple source files, and the one containing
> main might not be C++ while another is.  I don't know if there are any
> such instances in PETSc.
True. I think we just have to have a policy against that.
> I can change the build rules for tests with C++ sources later today.
Cool.
    Matt
experiments lead.
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <http://www.caam.rice.edu/~mk51/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20171231/3e3b0394/attachment-0001.html>
