[petsc-dev] snes_type test
Mark Adams mfadams at lbl.gov
Wed Aug 16 10:44:22 CDT 2017
I see, I had a tiny time step that make the Jacobian big and the errors
small.
On Thu, Aug 17, 2017 at 12:30 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Thu, Aug 17, 2017 at 12:22 AM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Aug 16, 2017 at 10:14 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I just want to check the interpretation of snes_type test. Is this
>>> pretty conclusively good?
>> It looks right, but the entires in the Jacobian are crazy. You should
>> non-dimensionalize first.
> This is non-dimensionalize and it is 2D FE 2nd order equation so
> everything should be O(1), that is, there is no 1/h like term. And the
> domain is (1) and the grid is small so h is O(1) anyway.
>>   Matt
>>> Testing hand-coded Jacobian, if the ratio is
>>> O(1.e-8), the hand-coded Jacobian is probably correct.
>>> Run with -snes_test_display to show difference
>>> of hand-coded and finite difference Jacobian.
>>> Norm of matrix ratio 1.38299e-16, difference 1.11738 (user-defined state)
>>> Norm of matrix ratio 9.50529e-09, difference 7.67972e+07 (constant state
>>> -1.0)
>>> Norm of matrix ratio 1.07438e-08, difference 8.68036e+07 (constant state
>>> 1.0)
>> experiments lead.
>> -- Norbert Wiener
>> http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170817/4df6a6c4/attachment.html>
