[petsc-dev] Bad tags
Sean Farley sean at farley.io
Sun Apr 23 22:02:49 CDT 2017
Satish Balay <balay at mcs.anl.gov> writes:
> On Sun, 23 Apr 2017, Satish Balay wrote:
>> Hope bitbucket has a way to control the push of tags..
> There is a mention of 'tag' in branch permissions - but its not clear how that works.
> https://confluence.atlassian.com/bitbucket/branch-permissions-385912271.html
> I've added these tags to the 'brach permission' list - don't know if
> it will prevent a (future) push or not..
Yeah, that's really not clear at all. The restrictions you set up
*should* work so if they don't, lemme know. I've forwarded this along to
our doc writers.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170423/aab16d05/attachment.sig>
