[petsc-dev] PETSC_DIR and PETSC_ARCH: used to distinguish between multiple applications ?
Kevin Buckley
kevin.buckley.ecs.vuw.ac.nz at gmail.com
Sun Apr 23 19:08:25 CDT 2017
Been a while since I have(re)installed a PETSc, but I have just
come into install it as a dependecy for a different package to
that for which I have installed it in the past.
The original package has a requirement for
--with-clanguage=cxx
whereas the current one doesn't, but it does have a requirement for
different external packages, eg hypre.
In terms of laying out PETSc, can (should ?) one use PETSC_DIR
and PETSC_ARCH: to combine everything PETSc-related under one,
top-level, say
/path/to/PETSC/3.7.5
with subdirs, or do the differing requirements demand two different "top-level "
/path/to/PETSC/3.7.5/Package1
/path/to/PETSC/3.7.5/Package2
hierachies, each then with duplicated files across the two?
Any pointers welcome,
Kevin
Kevin M. Buckley
eScience Consultant
School of Engineering and Computer Science
Victoria University of Wellington
New Zealand
