[petsc-dev] How come TSBDF has its own flag for turning on adaptivity?
Tue Apr 18 18:36:35 CDT 2017
   Lisandro,
  TSBDFUseAdapt - Use time-step adaptivity with the BDF method
  Logically Collective on TS
  Input Parameter:
+  ts - timestepping context
-  use - flag to use adaptivity
  Options Database:
.  -ts_bdf_adapt
Is there anyway this can be removed so the standard TS flags can be used to control turning on adaptivity for TSBDF? Even if TSBDF needs its own custom adapt code that is fine, but it should be able to be turned on (probably should be on by default anyways) without a special switch.
  Barry
