[petsc-dev] WSL upgrade
Jed Brown jed at jedbrown.org
Wed Apr 12 22:30:06 CDT 2017
Satish Balay <balay at mcs.anl.gov> writes:
>> >> WSL can now run Windows executables from bash (and vice-versa).  Is this
>> >> now a viable way to create a Windows native build?
>> >> https://blogs.msdn.microsoft.com/commandline/2017/04/11/windows-10-creators-update-whats-new-in-bashwsl-windows-console/
>> > We'll still need a win32fe equivalent functionality somewhere..
>> Understood.  I'm not trying to deal with that just now, but I would very
>> much like to see a native Windows build without using cygwin.
>> > Also Note:
>> > https://blogs.msdn.microsoft.com/commandline/2016/10/19/interop-between-windows-and-bash/
>> > "Windows apps should NOT be used to open files in the Linux filesystem"
>> That blog is six months old and can't still apply considering that the example has
>>   echo hello > hello.txt
>>   notepad.exe hello.txt
> Ok - here is the difference between attempting a compile [with MS cl] on 'linux fs' vs 'windows fs'
> balay at mb:~/petsc/src/benchmarks$ pwd
> /home/balay/petsc/src/benchmarks
> balay at mb:~/petsc/src/benchmarks$ cl.exe sizeof.c
> Unable to translate current working directory. Using C:\Program Files (x86)\Microsoft Visual Studio\2017\Community
This is the error message that old blog post refers to
and the new post runs exactly the same command without error.  Can you
run "notepad.exe sizeof.c"?
> Microsoft (R) C/C++ Optimizing Compiler Version 19.10.25019 for x64
> Copyright (C) Microsoft Corporation.  All rights reserved.
> sizeof.c
> c1: fatal error C1083: Cannot open source file: 'sizeof.c': No such file or directory
> balay at mb:~/petsc/src/benchmarks$ cd /mnt/c/Users/balay/Documents/petsc/src/benchmarks/
> balay at mb:/mnt/c/Users/balay/Documents/petsc/src/benchmarks$ cl.exe sizeof.c
> sizeof.c
> Microsoft (R) Incremental Linker Version 14.10.25019.0
> /out:sizeof.exe
> sizeof.obj
>> > BTW: builds with ubuntu gcc goes through fine - but 'make alltest' randomly hangs..
>> Where are you running?
> On an experimental machine setup locally (so i can reset the OS as I
> please - I needed that as I was playing with developer releases)
> Note: even with win10 'creators update' - one has to set windows into
> developer mode for WSL to work.
>> The new blog claims that sshd works now, so it
>> must be possible to set up a Windows machine/VM so that we can ssh into
>> a bash shell.  That would vastly simplify the task of reproducing
>> Windows oddities.
> I'll have to check on that. From what I can recollect - a separate WSL
> would be required for each user - and the user account system is
> separate on WSL from windows accounts. So I wonder how sshd access
> would work. [and then figuring out how to get cl working via ssh]
We could make a petsc account and add our ssh keys, like we have done on
some other machines.
> Its easy enough to use rdesktop over ssh. I can set that up for you..
> [note: this mode limits to a a single user at a time]
> For windows/cygwin testbox - I do use sshd for automated testing..
> Satish
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20170412/4affda4c/attachment.sig>
