[petsc-dev] KNL MatMult performance and unrolling.
Richard Mills richardtmills at gmail.com
Thu Sep 29 13:24:32 CDT 2016
On Wed, Sep 28, 2016 at 1:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Mr Hong Zhang has found that removing the manual unrolling from
> MatMult_SeqAIJ_Inode() (at least with inode size 2) results in a good bump
> in performance on KNL and pointed me to the Intel gospel
> https://software.intel.com/en-us/articles/avoid-manual-loop-unrolling
> which we've always ignored in the past. It would be good try the unrolled
> and non-unrolled also on Xeon.
>    We've never done a good job of managing our unrolling, where, how and
> when we do it and macros for unrolling such as PetscSparseDensePlusDot.
> Intel would say just throw it all away.
Talking to some colleagues at Intel, the only time they do manual unrolling
is for cases with nice unit-stride accesses and in which they are using
Intel intrinsic instructions.  Otherwise, it is best to rely on the
compiler to do this.  If you know a really good reason that a particular
unrolling factor should be used, you can suggest it to the compiler with
"#pragma unroll (n)".
My guess is that, with the Intel compiler, at least, we are better off
letting it do the unrolling.  I'm not sure about other compilers out there.
--Richard
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160929/7db44549/attachment.html>
