[petsc-dev] errors for /petsc/src/ts/examples/tutorials/ex29.c
Fri Sep 16 13:18:15 CDT 2016
> On Sep 15, 2016, at 11:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  A perhaps better fix is to finally remove this from the DMDCreateNd() calls
>>  /* This violates the behavior for other classes, but right now users expect negative dimensions to be handled this way */
>>  ierr = DMSetFromOptions(*da);CHKERRQ(ierr);
>>  ierr = DMSetUp(*da);CHKERRQ(ierr);
>>  Perhaps we could remove both of these lines from those calls and require every use of DMDCreateNd() to add the
>> DMSetUp() call. Then the user is free to insert a DMSetFromOptions() in between or not. We remove the negative value business which is hokey anyway?
>>  So in the use of DMDAGetReducedDMDA() it could call DMDACreate2d() then the DMSetUp() but skip the DMSetFromOptions() line.
> I won't stop you, but I'm not sure that's worth it.  We don't use
> MatCreateAIJ type "convenience" functions in library code, so why should
> we use the DMDACreate*d convenience functions?  Presumably doing so
> would remove the conditionals (over dimension) that we have now.  Or
> perhaps we should do both?
   Yeah, we probably should do both.
  Barry
