[petsc-dev] Hijacked MPI calls...
Thu Sep 15 23:11:29 CDT 2016
> On Sep 15, 2016, at 11:06 PM, Jed Brown <jed at jedbrown.org> wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
>>>> And this one is perhaps for Matt..
>>> Ops - perhaps Jed needs to look at this..
>>>>          CC arch-clang-cmplx/obj/src/dm/impls/composite/pack.o
>>>> /home/balay/petsc/src/dm/impls/composite/pack.c:657:17: warning: passing an object that undergoes default argument promotion to 'va_start' has undefined behavior [-Wvarargs]
>>>>  va_start(Argp,imode);
>>>> /home/balay/petsc/src/dm/impls/composite/pack.c:641:61: note: parameter of type 'InsertMode' is declared here
>>>> PetscErrorCode  DMCompositeGather(DM dm,Vec gvec,InsertMode imode,...)
>>>> 1 warning generated.
>> The fix here is:
>> -PetscErrorCode  DMCompositeGather(DM dm,Vec gvec,InsertMode imode,...)
>> +PetscErrorCode  DMCompositeGather(DM dm,InsertMode imode,Vec gvec,...)
>> [Barry is ok - but Jed,Matt might object?]
> It's annoying, but it appears to be needed.  It's screwy because enum
> ought to be handled no differently than int for this purpose.
   Yeah, we checked and sizeof(enum type) = 4 so there is no need for promotion so I blame it on compiler flakiness.
