[petsc-dev] Hijacked MPI calls...
Tue Sep 13 10:37:05 CDT 2016
> On Sep 13, 2016, at 10:13 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> There is stuff like:
> src/mat/order/fn1wd.c
> -    kstop = (i__2 = xadj[node + 1], (PetscInt)PetscAbsInt(i__2)) - 1;
> +    kstop = (PetscInt)PetscAbsInt(xadj[node + 1]) - 1;
> Perhaps PetscAbsInt() type stuff should be switched over to static inline?
> Or use a different notation?
> i__2  = xadj[node + 1];
> kstop = (PetscInt)PetscAbsInt(i__2) - 1;
   This is the way any normal person would write it :-)
> And for the following - use 'void' as compiler suggests?
> a/src/mat/utils/pheap.c
> -  while (par = Parent(loc), Value(h,par) > val) {
> +  while ((void)(par = Parent(loc)), Value(h,par) > val) {
> a/src/dm/impls/plex/plexdistribute.c
> -      for (q = 0; q < numAdj || (adj[numAdj++] = support[s],0); ++q) {
> +      for (q = 0; q < numAdj || ((void)(adj[numAdj++] = support[s]),0); ++q) {
   Does the (void) work to eliminate the warning?
  Barry
> And this one is perhaps for Matt..
>          CC arch-clang-cmplx/obj/src/dm/impls/composite/pack.o
> /home/balay/petsc/src/dm/impls/composite/pack.c:657:17: warning: passing an object that undergoes default argument promotion to 'va_start' has undefined behavior [-Wvarargs]
>  va_start(Argp,imode);
> /home/balay/petsc/src/dm/impls/composite/pack.c:641:61: note: parameter of type 'InsertMode' is declared here
> PetscErrorCode  DMCompositeGather(DM dm,Vec gvec,InsertMode imode,...)
> 1 warning generated.
> Satish
> On Mon, 12 Sep 2016, Barry Smith wrote:
>>  Satish,
>>   Interesting. We can probably get rid of most of the other warnings easily; it looks like mostly frivolous use of the , notation.
>>   Barry
>>> On Sep 12, 2016, at 11:19 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> The attached patch gets rid of most of the warnings [esp MPI usage
>>> from PETSc code - with the logging wrappers].
>>> [also added to balay/clang-Wcomma]
>>> Satish
>>> On Mon, 12 Sep 2016, Satish Balay wrote:
>>>> ok - so you are using CFLAGS=-Wcomma on your build..
>>>> I see warnings now. Attaching make.log
>>>> Satish
>>>> On Mon, 12 Sep 2016, Eric Chamberland wrote:
>>>>> Le 2016-09-12 à 17:32, Satish Balay a écrit :
>>>>>> Do you get these warnings with PETSc library build aswell?
>>>>> I can't tell since I didn't tried to build PETSc with clang...
>>>>>> The logging code tries to log all messages in library and in
>>>>>> application - and prints a summary with -info.
>>>>>> You can disable logging in your build with configure option: --with-log=0
>>>>>> Or you can define the PETSC_HAVE_BROKEN_RECURSIVE_MACRO in your
>>>>>> code/compile - and the wrappers will be skipped..
>>>>> ok, so these may be good workaround for me to keep -Wcomma activated on our
>>>>> "push server" that filters incoming commits...
>>>>> Thanks!!!
>>>>> Eric
>>> <clang-Wcomma.patch><make.log>
