[petsc-dev] Hijacked MPI calls...
Mon Sep 12 16:32:33 CDT 2016
Do you get these warnings with PETSc library build aswell?
The logging code tries to log all messages in library and in
application - and prints a summary with -info.
You can disable logging in your build with configure option: --with-log=0
Or you can define the PETSC_HAVE_BROKEN_RECURSIVE_MACRO in your
code/compile - and the wrappers will be skipped..
Satish
On Mon, 12 Sep 2016, Eric Chamberland wrote:
> Hi,
> I just discovered that all my calls to MPI are replaced by PETSc #define
> macros...
> I don't really care, but I now have this warning with clang 3.9.0:
> /pmi/cmpbib/compilation_BIB_gcc_redhat_squash/COMPILE_AUTO/GIREF/src/commun/Parallele/PABroadcast.icc:324:41:
> warning: possible misuse of comma operator here [-Wcomma]
>        int lErreurMPI = ((petsc_wait_ct++,petsc_sum_of_waits_ct++,0) ||
> MPI_Wait(&(aIdComm[0]),&lStatus));
> /pmi/cmpbib/compilation_BIB_gcc_redhat_squash/COMPILE_AUTO/GIREF/src/commun/Parallele/PABroadcast.icc:324:26:
> note: cast expression to void to silence warning
>                          static_cast<void>( )
> I have many files to modify in my code if I want to silence this warning (with
> pragmas)...
> But before doing so, I have 2 questions:
> - Would you consider doing static_cast<void>( ) as suggested by clang to
> silence the warnings?
> - Does PETSc lib really wants to count *my* calls to MPI functions?
> I don't have a strong opinion if PETSc should #define or not all MPI calls,
> but about -Wcomma warnings, I do: I want this warning to be signaled into my
> code because all the ones I have found where unwanted uses of coma operator...
> and I want to keep the code clean into the future...
> The "offending" macros are all in petsclog.h which is included by petscsys.h.
> thanks,
> Eric
