[petsc-dev] build of manual
Hong Zhang hongzhang at anl.gov
Mon Sep 12 10:15:55 CDT 2016
The problem is in line 5216
\noindent\textbf{\trl{TSAdapt} basic.}
If you change the word TSAdapt (e.g. add a random character), the error would disappear. Probably it is conflicting with something else.
Hong
> On Sep 12, 2016, at 10:01 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>  Run
> make manual.pdf LOC=${PETSC_DIR} GONULL=""
> and it should print the process to the screen so you see what is breaking the latex.
>   Barry
>> On Sep 12, 2016, at 9:54 AM, Mark Adams <mfadams at lbl.gov> wrote:
>> Anyone have any idea what the problem is here?
>> 10:51 mark/gamg-docs * ~/Codes/petsc/src/docs/tex/manual$ make manual.pdf LOC=${PETSC_DIR}
>> /Library/TeX/texbin/pdflatex -halt-on-error manual1  > /dev/null 2>&1
>> make: *** [manual.pdf] Error 1
>> I've made alldoc in PETSC_DIR.
>> On Tue, Nov 4, 2014 at 4:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>  You need to be in the correct directory to run the make. and likely you also need the LOC=${PETSC_DIR}
>>> On Nov 4, 2014, at 3:15 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> Thanks Barry, it does not seem to pick changes in part2.tex:
>>> 16:14 mark/gamgdoc ~/Codes/petsc/docs$ make manual.pdf
>>> make: Nothing to be done for `manual.pdf'.
>>> On Tue, Nov 4, 2014 at 4:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>> On Nov 4, 2014, at 2:41 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> Thanks Satish,  and I do see this in the web page:
>>>> make alldoc LOC=${PETSC_DIR}
>>>> This takes a long time.
>>>   Yes a very long time
>>>> Is the workflow edit part2.tex; make alldoc … ?
>>>  No, once you have done the make alldoc once you can simply run make manual.pdf in the manual directory as you edit the users manual.
>>>   Barry
>>>> On Tue, Nov 4, 2014 at 2:52 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> You'll have to do 'make alldoc1' from PETSC_DIR - or atleast
>>>> part of it..
>>>> alldoc1: chk_loc deletemanualpages chk_concepts_dir
>>>>        -${PYTHON} bin/maint/countpetsccits.py
>>>>        -${OMAKE} ACTION=manualpages_buildcite tree_basic LOC=${LOC}
>>>>        - at sed -e s%man+../%man+manualpages/% ${LOC}/docs/manualpages/manualpages.cit > ${LOC}/docs/manualpages/htmlmap
>>>>        - at cat ${PETSC_DIR}/src/docs/mpi.www.index >> ${LOC}/docs/manualpages/htmlmap
>>>>        -cd src/docs/tex/manual; ${OMAKE} manual.pdf LOC=${LOC}
>>>> Satish
>>>> On Tue, 4 Nov 2014, Mark Adams wrote:
>>>>> I get this error when I try to make the manual:
>>>>> 14:47 mark/gamgdoc ~/Codes/petsc/src/docs/tex/manual$ latex manual.tex
>>>>> This is pdfTeX, Version 3.14159265-2.6-1.40.15 (TeX Live 2014) (preloaded
>>>>> format=latex)
>>>>> restricted \write18 enabled.
>>>>> entering extended mode
>>>>> (./manual.tex
>>>>> LaTeX2e <2014/05/01>
>>>>> Babel <3.9k> and hyphenation patterns for 78 languages loaded.
>>>>> [snip]
>>>>> (/usr/local/texlive/2014/texmf-dist/tex/generic/pgf/frontendlayer/tikz/librarie
>>>>> s/tikzlibrarytopaths.code.tex))) (../sty/verbatim.sty
>>>>> Style-Option: `verbatim' v1.4d <91/04/24> (RmS)
>>>>> English Documentation          <91/04/24> (RmS)
>>>>> ) (../sty/tpage.sty) (../sty/here.sty) (../sty/anlhelper.sty)
>>>>> (../sty/trl.sty
>>>>> LaTeX Warning: You have requested package `../sty/trl',
>>>>>               but the package provides `trl'.
>>>>> ! LaTeX Error: Missing \begin{document}.
>>>>> See the LaTeX manual or LaTeX Companion for explanation.
>>>>> Type  H <return>  for immediate help.
>>>>> l.38 h
>>>>>      yperbaseurl
>>>>> On Tue, Nov 4, 2014 at 2:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>>>>>  This is not enough information to help debug your problem.
>>>>>>> On Nov 4, 2014, at 1:26 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>> I am getting errors building the manual and had to comment this out:
>>>>>>> %hyperbaseurl
>>>>>>> And I now get this error:
>>>>>>> ! LaTeX Error: File `part1tmp.tex' not found.
>>>>>>> Mark
