[petsc-dev] git problem
Sean Farley sean at farley.io
Sat Sep 10 17:24:59 CDT 2016
Barry Smith <bsmith at mcs.anl.gov> writes:
>    This came up and I haven't seen it before, google is not helpful in resolving it.
> git pull http://bitbucket.org/vlc1/petsc vlc1/dmcomposite
> fatal: unable to access 'https://bitbucket.org/vlc1/petsc/': SSL certificate problem: unable to get local issuer certificate
Huh. We did change our certs back in May,
https://blog.bitbucket.org/2016/05/04/2847/
but that doesn't look like your error. Do you have any ssl settings in
your gitconfig?
