[petsc-dev] git problem
Fri Sep 9 21:52:40 CDT 2016
On Fri, Sep 9, 2016 at 9:51 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Sep 9, 2016, at 9:45 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Fri, Sep 9, 2016 at 8:54 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    This came up and I haven't seen it before, google is not helpful in
> resolving it.
> > git pull http://bitbucket.org/vlc1/petsc vlc1/dmcomposite
> > fatal: unable to access 'https://bitbucket.org/vlc1/petsc/': SSL
> certificate problem: unable to get local issuer certificate
> > Don't use https://, use the ssh:// protocol. You might have to fix it
> in your .git/config
>   Note I'm pulling from some other guys repository, not the PETSc where my
> ssh key will work. Until today this use to work for "other guys"
> repositories.
SSH keys are not per repo, they work for Bitbucket. You can use the SSH
form for any repo on the site.
  Matt
> >    Matt
> > Meanwhile things like
> > $ git checkout master
> > Switched to branch 'master'
> > Your branch is behind 'origin/master' by 4 commits, and can be
> fast-forwarded.
> >   (use "git pull" to update your local branch)
> > ~/Src/petsc/src/ts/examples/tutorials (master<) arch-basic
> > $ git pull
> > Updating acfa351..b3a4586
> > Fast-forward
> >  bin/maint/buildtest                     |  7 +------
> >  bin/maint/runhtml.py                    |  1 +
> >  config/PETSc/Configure.py               |  4 +++-
> >  src/ksp/ksp/examples/tutorials/makefile |  8 ++++----
> >  src/mat/examples/tests/makefile         | 30
> >  5 files changed, 24 insertions(+), 26 deletions(-)
> > ~/Src/petsc/src/ts/examples/tutorials (master=) arch-basic
> > seem to work fine. I can also go to  http://bitbucket.org/vlc1/petsc
> via the browser and it displays the repository fine. So what is the issue?
> >   Thanks
> >   Barry
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160909/9e9a9758/attachment.html>
