[petsc-dev] git problem
Fri Sep 9 20:54:18 CDT 2016
   This came up and I haven't seen it before, google is not helpful in resolving it.
git pull http://bitbucket.org/vlc1/petsc vlc1/dmcomposite
fatal: unable to access 'https://bitbucket.org/vlc1/petsc/': SSL certificate problem: unable to get local issuer certificate
Meanwhile things like
$ git checkout master
Switched to branch 'master'
Your branch is behind 'origin/master' by 4 commits, and can be fast-forwarded.
  (use "git pull" to update your local branch)
~/Src/petsc/src/ts/examples/tutorials (master<) arch-basic
$ git pull
Updating acfa351..b3a4586
Fast-forward
 bin/maint/buildtest                     |  7 +------
 bin/maint/runhtml.py                    |  1 +
 config/PETSc/Configure.py               |  4 +++-
 src/ksp/ksp/examples/tutorials/makefile |  8 ++++----
 src/mat/examples/tests/makefile         | 30 +++++++++++++++---------------
 5 files changed, 24 insertions(+), 26 deletions(-)
~/Src/petsc/src/ts/examples/tutorials (master=) arch-basic
seem to work fine. I can also go to  http://bitbucket.org/vlc1/petsc via the browser and it displays the repository fine. So what is the issue?
  Thanks
  Barry
