[petsc-dev] Fix errors for petsc-3.7.3/petsc/src/ts/examples/tutorials/ex29.c
Lulu Liu lulu.liu at kaust.edu.sa
Wed Sep 7 14:37:25 CDT 2016
When I try to make ex29 in the directory
/petsc-3.7.3/petsc/src/ts/examples/tutorials/,  it shows following errors.
It seems that we need to  define Mat J (or other names)  instead of Mat I).
Thanks!
/Users/lulu/petsc/petsc-3.7.3/petsc/src/ts/examples/tutorials/ex29.c:42:18:
error:
      expected identifier or '('
 * Mat            I;*
/usr/include/complex.h:42:11: note: expanded from macro 'I'
#define I _Complex_I
/usr/include/complex.h:40:21: note: expanded from macro '_Complex_I'
#define _Complex_I (__extension__ 1.0iF)
error:
      expected ')'
note:
      to match this '('
/usr/include/complex.h:40:20: note: expanded from macro '_Complex_I'
/Users/lulu/petsc/petsc-3.7.3/petsc/src/ts/examples/tutorials/ex29.c:58:41:
error:
      cannot take the address of an rvalue of type '_Complex float'
  ierr = DMCreateInterpolation(cdmc,cdm,&I,&vscale);CHKERRQ(ierr);
/Users/lulu/petsc/petsc-3.7.3/petsc/src/ts/examples/tutorials/ex29.c:59:22:
error:
      passing '_Complex float' to parameter of incompatible type 'Mat'
      (aka 'struct _p_Mat *')
  ierr = MatRestrict(I,c,cc);CHKERRQ(ierr);
/Users/lulu/petsc/petsc-3.7.3/petsc/include/petscmat.h:557:44: note: passing
      argument to parameter here
PETSC_EXTERN PetscErrorCode MatRestrict(Mat,Vec,Vec);
/Users/lulu/petsc/petsc-3.7.3/petsc/src/ts/examples/tutorials/ex29.c:62:21:
error:
  ierr = MatDestroy(&I);CHKERRQ(ierr);
5 errors generated.
make: *** [ex29.o] Error 1
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160907/5140173f/attachment.html>
