[petsc-dev] what happened to RAP timers?
Mark Adams mfadams at lbl.gov
Tue Sep 6 07:43:53 CDT 2016
I am actually seeing RAP now ... and the GAMG timers seem to cover GAMG
setup pretty well.
On Mon, Sep 5, 2016 at 1:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> #undef __FUNCT__
> #define __FUNCT__ "MatPtAP"
>    MatPtAP - Creates the matrix product C = P^T * A * P
>    Neighbor-wise Collective on Mat
>    Input Parameters:
> +  A - the matrix
> .  P - the projection matrix
> .  scall - either MAT_INITIAL_MATRIX or MAT_REUSE_MATRIX
> -  fill - expected fill as ratio of nnz(C)/(nnz(A) + nnz(P)), use
> PETSC_DEFAULT if you do not have a good estimate
>           if the result is a dense matrix this is irrelevent
>    Output Parameters:
> .  C - the product matrix
>    Notes:
>    C will be created and must be destroyed by the user with MatDestroy().
>    This routine is currently only implemented for pairs of AIJ matrices
> and classes
>    which inherit from AIJ.
>    Level: intermediate
> .seealso: MatPtAPSymbolic(), MatPtAPNumeric(), MatMatMult(), MatRARt()
> PetscErrorCode MatPtAP(Mat A,Mat P,MatReuse scall,PetscReal fill,Mat *C)
>   PetscErrorCode ierr;
>   PetscErrorCode (*fA)(Mat,Mat,MatReuse,PetscReal,Mat*);
>   PetscErrorCode (*fP)(Mat,Mat,MatReuse,PetscReal,Mat*);
>   PetscErrorCode (*ptap)(Mat,Mat,MatReuse,PetscReal,Mat*)=NULL;
>   PetscBool      viatranspose=PETSC_FALSE,viamatmatmatmult=PETSC_FALSE;
>   PetscFunctionBegin;
>   ierr = PetscOptionsGetBool(((PetscObject)A)->options,((
> PetscObject)A)->prefix,"-matptap_viatranspose",&
> viatranspose,NULL);CHKERRQ(ierr);
> PetscObject)A)->prefix,"-matptap_viamatmatmatmult",&
> viamatmatmatmult,NULL);CHKERRQ(ierr);
>   PetscValidHeaderSpecific(A,MAT_CLASSID,1);
>   PetscValidType(A,1);
>   MatCheckPreallocated(A,1);
>   if (!A->assembled) SETERRQ(PetscObjectComm((
> PetscObject)A),PETSC_ERR_ARG_WRONGSTATE,"Not for unassembled matrix");
>   if (A->factortype) SETERRQ(PetscObjectComm((
> PetscObject)A),PETSC_ERR_ARG_WRONGSTATE,"Not for factored matrix");
>   PetscValidHeaderSpecific(P,MAT_CLASSID,2);
>   PetscValidType(P,2);
>   MatCheckPreallocated(P,2);
>   if (!P->assembled) SETERRQ(PetscObjectComm((
>   if (P->factortype) SETERRQ(PetscObjectComm((
>   if (A->rmap->N!= A->cmap->N) SETERRQ2(PetscObjectComm((
> PetscObject)A),PETSC_ERR_ARG_SIZ,"Matrix A must be square, %D !=
> %D",A->rmap->N,A->cmap->N);
>   if (P->rmap->N != A->cmap->N) SETERRQ2(PetscObjectComm((
> PetscObject)A),PETSC_ERR_ARG_SIZ,"Matrix dimensions are incompatible, %D
> != %D",P->rmap->N,A->cmap->N);
>   if (fill == PETSC_DEFAULT || fill == PETSC_DECIDE) fill = 2.0;
>   if (fill < 1.0) SETERRQ1(PetscObjectComm((PetscObject)A),PETSC_ERR_ARG_SIZ,"Expected
> fill=%g must be >= 1.0",(double)fill);
>   if (scall == MAT_REUSE_MATRIX) {
>     PetscValidPointer(*C,5);
>     PetscValidHeaderSpecific(*C,MAT_CLASSID,5);
>     if (viatranspose || viamatmatmatmult) {
>       Mat Pt;
>       ierr = MatTranspose(P,MAT_INITIAL_MATRIX,&Pt);CHKERRQ(ierr);
>       if (viamatmatmatmult) {
>         ierr = MatMatMatMult(Pt,A,P,scall,fill,C);CHKERRQ(ierr);
>       } else {
>         Mat AP;
>         ierr = MatMatMult(A,P,MAT_INITIAL_MATRIX,fill,&AP);CHKERRQ(ierr);
>         ierr = MatMatMult(Pt,AP,scall,fill,C);CHKERRQ(ierr);
>         ierr = MatDestroy(&AP);CHKERRQ(ierr);
>       ierr = MatDestroy(&Pt);CHKERRQ(ierr);
>     } else {
>       ierr = PetscLogEventBegin(MAT_PtAP,A,P,0,0);CHKERRQ(ierr);
>       ierr = PetscLogEventBegin(MAT_PtAPNumeric,A,P,0,0);CHKERRQ(ierr);
>       ierr = (*(*C)->ops->ptapnumeric)(A,P,*C);CHKERRQ(ierr);
>       ierr = PetscLogEventEnd(MAT_PtAPNumeric,A,P,0,0);CHKERRQ(ierr);
>       ierr = PetscLogEventEnd(MAT_PtAP,A,P,0,0);CHKERRQ(ierr);
>     PetscFunctionReturn(0);
>   fA = A->ops->ptap;
>   fP = P->ops->ptap;
>   if (fP == fA) {
>     if (!fA) SETERRQ1(PetscObjectComm((PetscObject)A),PETSC_ERR_SUP,"MatPtAP
> not supported for A of type %s",((PetscObject)A)->type_name);
>     ptap = fA;
>   } else {
>     /* dispatch based on the type of A and P from their PetscObject's
> PetscFunctionLists. */
>     char ptapname[256];
>     ierr = PetscStrcpy(ptapname,"MatPtAP_");CHKERRQ(ierr);
>     ierr = PetscStrcat(ptapname,((PetscObject)A)->type_name);
> CHKERRQ(ierr);
>     ierr = PetscStrcat(ptapname,"_");CHKERRQ(ierr);
>     ierr = PetscStrcat(ptapname,((PetscObject)P)->type_name);
> CHKERRQ(ierr);
>     ierr = PetscStrcat(ptapname,"_C");CHKERRQ(ierr); /* e.g., ptapname =
> "MatPtAP_seqdense_seqaij_C" */
>     ierr = PetscObjectQueryFunction((PetscObject)P,ptapname,&ptap);
> CHKERRQ(ierr);
>     if (!ptap) SETERRQ2(PetscObjectComm((PetscObject)A),PETSC_ERR_ARG_INCOMP,"MatPtAP
> requires A, %s, to be compatible with P, %s",((PetscObject)A)->type_
>     Mat Pt;
>       ierr = PetscInfo(*C,"MatPtAP via MatMatMatMult\n");CHKERRQ(ierr);
>     } else {
>       Mat AP;
>       ierr = PetscInfo(*C,"MatPtAP via MatTranspose and
>   } else {
>     ierr = (*ptap)(A,P,scall,fill,C);CHKERRQ(ierr);
> > On Sep 5, 2016, at 4:19 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > Barry,
> > THis code looks to me like it should work, but it does not seem to. What
> code were you looking at?
> >   ierr = PetscOptionsGetBool(NULL,NULL,"-matrap",&rap,NULL);CHKERRQ(
> ierr);
> >   if (scall == MAT_INITIAL_MATRIX) {
> >     ierr = PetscLogEventBegin(MAT_PtAPSymbolic,A,P,0,0);CHKERRQ(ierr);
> >     if (rap) { /* do R=P^T locally, then C=R*A*P */
> >       ierr = MatPtAPSymbolic_MPIAIJ_MPIAIJ(A,P,fill,C);CHKERRQ(ierr);
> >     } else {       /* do P^T*A*P */
> >       ierr = MatPtAPSymbolic_MPIAIJ_MPIAIJ_
> ptap(A,P,fill,C);CHKERRQ(ierr);
> >     ierr = PetscLogEventEnd(MAT_PtAPSymbolic,A,P,0,0);CHKERRQ(ierr);
> > On Sun, Sep 4, 2016 at 9:05 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Mark,
> >    Look at the source code for MatPtAP. It depends on the approach to
> how it is computed what logging takes place. I am not sure the rational for
> this exact logging is, it would seem better to always log it so perhaps
> that could be changed.
> >   Barry
> > > On Sep 4, 2016, at 7:10 PM, Mark Adams <mfadams at lbl.gov> wrote:
> > > I don't seem to be seeing RAP (MatPtAP, or whatever) profile data. Did
> this get dumped?
> > > I see that there are two timers in GAMG that I can scrap but if RAP is
> not timed then I will add that to GAMG profile data.
> > > Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160906/028258f1/attachment.html>
