[petsc-dev] How to get block size into a DM
Mon Sep 5 06:27:22 CDT 2016
On Mon, Sep 5, 2016 at 3:57 AM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sun, Sep 4, 2016 at 8:35 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Sep 4, 2016 at 7:07 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> On Sat, Sep 3, 2016 at 11:05 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Sat, Sep 3, 2016 at 11:12 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>> The DM in snes/ex56 does elasticity but the block size does not get
>>>>> into vectors. It does something like this:
>>>>> PetscFECreateDefault(dm, dim, dim, PETSC_FALSE, NULL, 3,
>>>>> &fe);CHKERRQ(ierr); /* elasticity */
>>>>> DMGetDS(dm, &prob);CHKERRQ(ierr);
>>>>> PetscDSSetDiscretization(prob, 0, (PetscObject) fe);CHKERRQ(ierr);
>>>>> DMCreateGlobalVector(dm,&xx);
>>>>> The block size of xx is not 3. (dim==3). It is not clear to me how to
>>>>> make this work.
>>>> The DM determines the block size based on the Section. There could be a
>>>> bug,
>>> I suspect that I just found a hole in the combinatorics (finite!) that
>>> is Plex. I use -mat_block_size 3, so I could see how Plex might not pick it
>>> up.
>> Perhaps.
"Give me the branch and exact command line to run."
   Matt
> My pull request for snes/ex56 has:
> ierr = VecNorm(xx,NORM_INFINITY,&mdisp[iter]);CHKERRQ(ierr);
> When I tried to use VecStrideNorm I got the error that block size was not
> set. You can't set it manually so I was stuck (not a big deal, but there is
> either a bug in Plex or a bug in the way that I am using it).
> Thanks,
>>   Matt
>>> All I do is call DMCreateMatrix(dm, &Amat);
>>> And Amat get its w/o and explicit setfromoptions.
>>> but first did you apply
>>>> a BC that would wreck the block size? Namely did you constrain just one
>>>> or two unknowns at a point?
>>> No
>>>>   Matt
>>>>> snes/ex56 does use -mat_block_size 3.
>>>>> Mark
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160905/24e9beeb/attachment.html>
