[petsc-dev] fortran literals
William Gropp wgropp at illinois.edu
Fri Sep 2 00:51:15 CDT 2016
This is true.  The meaning of integer values of kind is up to the implementation, and at least two choices are in use.
Bill
William Gropp
Acting Director and Chief Scientist, NCSA
Director, Parallel Computing Institute
Thomas M. Siebel Chair in Computer Science
University of Illinois Urbana-Champaign
On Sep 1, 2016, at 6:15 PM, Blaise A Bourdin <bourdin at lsu.edu> wrote:
> If I recall correctly, fortran does not mandate that "selected_real_kind(5)" means the same across compilers, so that hardcoding kind values may not be portable.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160902/db2bf3f6/attachment.html>
