[petsc-dev] fortran literals
Scott Kruger kruger at txcorp.com
Thu Sep 1 16:46:59 CDT 2016
Lisandro's description is the most natural way for a modern fortran
programmer.
But for completeness, this is equivalent:
    x=REAL(0.123456789123456789123456789,KIND=PETSC_REAL_KIND)
Similarly, for complex numbers we have:
   xc=(0.1_PETSC_REAL_KIND,0.2_PETSC_REAL_KIND)
or
   xc=CMPLX(0.1,0.2,KIND=PETSC_REAL_KIND)
If you do not want to use the selected_real_kind
as Lisandro shows, you can also use the intrinsics
which are generally compiler independent:
https://gcc.gnu.org/onlinedocs/gcc-3.4.4/g77/Kind-Notation.html
That is,
   x=REAL(0.1,KIND=2)
or equivalently
   x=DBLE(0.1)
if you always want double precision regardless
of how PETSC_REAL_KIND is defined.
Scott
On 9/1/16 3:13 PM, Lisandro Dalcin wrote:
> On 1 September 2016 at 23:05, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>        I didn't have a solution to this
> ! These lines should be added to
> $PETSC_DIR/include/petsc/finclude/petscsysdef.h
> #if defined(PETSC_USE_REAL_SINGLE)
> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(5)
> #elif defined(PETSC_USE_REAL_DOUBLE)
> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(10)
> #elif defined(PETSC_USE_REAL___FLOAT128)
> integer, parameter :: PETSC_REAL_KIND = selected_real_kind(20)
> #endif
> ! User code should write literals this way
> PetscReal x
> x = 0.123456789123456789123456789_PETSC_REAL_KIND
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Extreme Computing Research Center (ECRC)
> King Abdullah University of Science and Technology (KAUST)
> http://ecrc.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 0109
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 974-1841
Boulder, CO 80303                Fax:   (303) 448-7756
