[petsc-dev] fortran literals
Lisandro Dalcin dalcinl at gmail.com
Thu Sep 1 16:13:41 CDT 2016
On 1 September 2016 at 23:05, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    I didn't have a solution to this
! These lines should be added to
$PETSC_DIR/include/petsc/finclude/petscsysdef.h
#if defined(PETSC_USE_REAL_SINGLE)
integer, parameter :: PETSC_REAL_KIND = selected_real_kind(5)
#elif defined(PETSC_USE_REAL_DOUBLE)
integer, parameter :: PETSC_REAL_KIND = selected_real_kind(10)
#elif defined(PETSC_USE_REAL___FLOAT128)
integer, parameter :: PETSC_REAL_KIND = selected_real_kind(20)
#endif
! User code should write literals this way
PetscReal x
x = 0.123456789123456789123456789_PETSC_REAL_KIND
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Extreme Computing Research Center (ECRC)
King Abdullah University of Science and Technology (KAUST)
http://ecrc.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 0109
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160902/491441e6/attachment.html>
