[petsc-dev] elliptic functions
Mark Adams mfadams at lbl.gov
Sat Oct 22 09:24:10 CDT 2016
On Sat, Oct 22, 2016 at 8:07 AM, Matthew Knepley <knepley at gmail.com> wrote:
> Boost is an unmitigated nightmare. What exactly do you need?
7.13.3 Legendre Form of Complete Elliptic IntegralsFunction: *double*
*gsl_sf_ellint_Kcomp* *(double k, gsl_mode_t mode)*Function: *int*
*gsl_sf_ellint_Kcomp_e* *(double k, gsl_mode_t mode, gsl_sf_result
* result)*
These routines compute the complete elliptic integral *K(k)* to the
accuracy specified by the mode variable mode. Note that Abramowitz & Stegun
define this function in terms of the parameter *m = k^2*.
Function: *double* *gsl_sf_ellint_Ecomp* *(double k, gsl_mode_t mode)*
Function: *int* *gsl_sf_ellint_Ecomp_e* *(double k, gsl_mode_t mode,
gsl_sf_result * result)*
> DLMF is a good reference:
>   http://dlmf.nist.gov/19.39
Yes, that is where I got a pointer to GSL. THere are 5 other open source
options:
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161022/d6866fe4/attachment.html>
Name: Screen Shot 2016-10-22 at 10.22.41 AM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161022/d6866fe4/attachment.png>
