[petsc-dev] Matt, existence of PetscOptionsFindPairPrefix_Private()
Wed Oct 19 21:04:25 CDT 2016
  Matt,
   In commit 514bf10d you introduced PetscOptionsFindPairPrefix_Private() I don't understand how Prefix distinguishes it from PetscOptionsFindPair_Private() in terms of what it does and why it has so much code duplication? You used it just in fieldsplit.c
   It uses PetscStrncmp while PetscOptionsFindPair_Private  uses PetscStrcasecmp  which seems inconsistent. It skips all the handling of _%d_ stuff in the options, that seems the main difference, did you want to skip this just for efficiency or because that broke something?
   Could you explain why it exists? I would like to get rid of it (if this requires an additional argument to PetscOptionsFindPair_Private() that is better than the diverging duplicate code.)
   Thanks
    Barry
