[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Mon Oct 10 17:14:56 CDT 2016
On Mon, 10 Oct 2016, Antonio Trande wrote:
> New builds:
> 32bit:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-i386/00463215-petsc/build.log.gz
> Section with errors: https://paste.fedoraproject.org/448011/
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-rawhide-i386/00463045-petsc/build.log.gz
Previosly you sent the above - and that was fine. Whats the difference between the above 2 builds?
How about running stuff [esp sequential tests] in valgrind  - whenever they fail?
Satish
> 64bit:
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-24-x86_64/00463215-petsc/build.log.gz
> Without errors.
> 32bit (Rhel6 systems):
> https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/epel-6-i386/00463215-petsc/build.log.gz
> Without errors.
