[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Antonio Trande anto.trande at gmail.com
Sun Oct 9 07:11:47 CDT 2016
On 10/09/2016 11:48 AM, Matthew Knepley wrote:
> On Sun, Oct 9, 2016 at 4:23 AM, Antonio Trande <anto.trande at gmail.com
> <mailto:anto.trande at gmail.com>> wrote:
>     On 10/08/2016 11:50 PM, Satish Balay wrote:
>     >> Do tests need internet by chance?
>     > Nope - but you might want to disable petscnagupgrade.py in
>     lib/petsc/conf/rules
>     How?
> Change the action for the chk_upgrade target to 'true'
I hope that it's right:
--- lib/petsc/conf/rules.orig	2016-07-24 19:18:20.000000000 +0200
+++ lib/petsc/conf/rules	2016-10-09 12:09:20.632035457 +0200
@@ -82,7 +82,7 @@
 	    user=`ls -l ${INSTALL_LIB_DIR}/$$LIBNAME.${SL_LINKER_SUFFIX}  | tr
-s ' ' | cut -d ' ' -f 3`; \
 	    echo "Libraries were built by user $$user; please contact him/her
to have them rebuilt."; \
 	    printf
"******************************************************"${PETSC_TEXT_NORMAL}"\n"
-	    false; \
+	    true; \
 	  fi; \
 	fi; \
 	done
PAPI disabled.
Please, see the result of testing at the bottom of this log:
https://copr-be.cloud.fedoraproject.org/results/sagitter/petsc/fedora-rawhide-x86_64/00462741-petsc/build.log.gz
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161009/1150763b/attachment.sig>
