[petsc-dev] Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
Antonio Trande anto.trande at gmail.com
Fri Oct 7 13:24:47 CDT 2016
On 10/07/2016 06:03 PM, Satish Balay wrote:
> On Fri, 7 Oct 2016, Matthew Knepley wrote:
>> On Fri, Oct 7, 2016 at 10:54 AM, Antonio Trande <anto.trande at gmail.com>
>> wrote:
>>> Hi all.
>>> This issue is related to discussion from dev-ML:
>>> http://lists.mcs.anl.gov/pipermail/petsc-dev/2016-October/019827.html
>>> What do cause the errors:
>>> + make -C build64 test
>>> make: Entering directory '/builddir/build/BUILD/petsc-3.7.3/build64'
>>> Running test examples to verify correct installation
>>> Using PETSC_DIR=/builddir/build/BUILD/petsc-3.7.3/build64 and
>>> PETSC_ARCH=x86_64
>>> /usr/bin/sh: line 20: 14262 Aborted                 (core dumped)
>>> /builddir/build/BUILD/petsc-3.7.3/build64/bin/petsc-mpiexec.uni -n 1
>>> ./ex19 -da_refine 3 -pc_type mg -ksp_type fgmres > ex19_1.tmp 2>&1
>>> process
>> Run with -start_in_debugger and give us the stack trace
> Or valgrind - which should be scriptable..
> make test MPIEXEC='$PETSC_DIR/bin/petscmpiexec -valgrind'
> Satish
Libraries rebuilt without optimization flags and tested with valgrind:
https://paste.fedoraproject.org/445728/
Antonio Trande
mailto: sagitter 'at' fedoraproject 'dot' org
http://fedoraos.wordpress.com/
https://fedoraproject.org/wiki/User:Sagitter
GPG Key: 0x6CE6D08A
Check on https://keys.fedoraproject.org/
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20161007/70c56dc9/attachment.sig>
