[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Jed Brown jed at jedbrown.org
Wed May 25 22:37:43 CDT 2016
Satish Balay <balay at mcs.anl.gov> writes:
> You should have done 'git push -f' You can repeat again..
Satish, please don't use this syntax for force pushes.  Prefer
 git push origin +mark/snes-ex65c
This is to avoid people with old versions of Git or a weird push.default
settings from obliterating other branches.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/8331dbf5/attachment.sig>
