[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Wed May 25 16:08:34 CDT 2016
On Wed, May 25, 2016 at 1:01 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 25 May 2016, Mark Adams wrote:
> > I'm doing an all test right now, what should I do after that?
> You have a PR on this branch. It gets automatically updated with all
> the changes on it.
> You can add in a comment saying - "its again ready for review".
OK, it was not clear if I should merge it.  I will let you do it.
> Someone [usually Barry or Jed or Matt] would raise concerns - or merge
> it to 'next' for you.. [and once the 'next' builds/example runs are
> clean - they would merge to master]
> However if there are concerns - you might have to do more
> fixes/rebases etc..
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/67f414d0/attachment.html>
