[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Mark Adams mfadams at lbl.gov
Wed May 25 13:22:07 CDT 2016
On Wed, May 25, 2016 at 11:14 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> This is hopeless..
> Did you reset your 'mark/snes-ex56c' again to the old stuff?
> I don't get any merge conflicts - If I start from Jed's rebased/branch
> commit f2cb8422898d35ef96e146caa3a95b2f879b25f1
I did this from the non-jed version.
> balay at asterix /home/balay/petsc (master=)
> $ git co -b test f2cb8422898d35ef96e146caa3a95b2f879b25f1
> Switched to a new branch 'test'
> balay at asterix /home/balay/petsc (test)
> $ git rebase -i master
> Successfully rebased and updated refs/heads/test.
Maybe I corrupted jed's branch. I now get a different error.  This rebase
pulled up a vi window and I replaced "pick" with "s" for commits that I
want to squash.
11:15 jed/mark/snes-ex56c= ~/Codes/petsc/src/snes/examples/tutorials$ git
rebase -i master
The previous cherry-pick is now empty, possibly due to conflict resolution.
If you wish to commit it anyway, use:
    git commit --allow-empty
Otherwise, please use 'git reset'
interactive rebase in progress; onto 9c9a9c5
Last commands done (93 commands done):
   pick 5a3406a added ex56 in snes, 3D linear elasticity using Plex on a
cube
   pick 95a678b DMP4est: fix coarseEdge calculation in transfer_Point
Next commands to do (102 remaining commands):
   pick 013797a Need to declare TSSSPList as PETSC_EXTERN so users can add
to the list
   pick f92a85d Latest boost release seems to handle shared libraries on
Mac properly so remove error message
You are currently rebasing branch 'jed/mark/snes-ex56c' on '9c9a9c5'.
Untracked files:
        mhdforest.aux
        mhdforest.pdf
        mhdforest.tex
        out
        out_alltest_ex56
        out_alltest_next
        src/dm/examples/tutorials/dmda-mpiio.pbvec
        src/dm/examples/tutorials/dmda.pbvec
        src/dm/examples/tutorials/gauss.h5
        src/dm/examples/tutorials/hdf5output.h5
        src/dm/impls/picell/
        src/ksp/ksp/examples/tutorials/.petscrc
        src/ksp/ksp/examples/tutorials/ex34_1.tmp
        src/ksp/ksp/examples/tutorials/ex34_2.tmp
        src/mat/examples/tests/ex191matrix
        src/mat/examples/tests/fort.7
        src/snes/examples/tests/base_module.mod
        src/snes/examples/tests/ex1f_2.tmp
        src/snes/examples/tests/extended_module.mod
        src/snes/examples/tests/function_module.mod
        src/snes/examples/tutorials/.petscrc
        src/snes/examples/tutorials/f90module.mod
        src/snes/examples/tutorials/f90moduleinterfaces.mod
        src/snes/examples/tutorials/petsc_kkt_solver.mod
        src/snes/examples/tutorials/petsc_kkt_solver_interfaces.mod
        src/sys/examples/tutorials/bag_data_module.mod
        src/sys/examples/tutorials/bag_interface_module.mod
        src/sys/examples/tutorials/binaryoutput
        src/sys/logging/examples/tutorials/filename.xml
        src/ts/examples/tutorials/SA-data/
        src/ts/examples/tutorials/advection-diffusion-reaction/SA-data/
        src/ts/examples/tutorials/petscshiftmod.mod
        src/ts/examples/tutorials/power_grid/SA-data/
        src/ts/examples/tutorials/power_grid/stability_9bus/SA-data/
        src/ts/examples/tutorials/power_grid/stability_9bus/out.bin
        src/vec/is/examples/tests/testfile
        src/vec/vec/examples/tests/ex29_bts_2_subset.tmp
        src/vec/vec/examples/tests/x.h5
        src/vec/vec/examples/tests/xH.pbvec
        src/vec/vec/examples/tests/xHmpi.pbvec
        src/vec/vec/examples/tutorials/mymodule.mod
nothing added to commit but untracked files present
Could not apply 95a678b879f0666d009cbaa65ec66f87451d4d65... DMP4est: fix
11:19 1 jed/mark/snes-ex56c|REBASE-i 93/195
> <after a editor prompt with the following commits - for interactive rebase>
> pick 849c9e8 changed Cheby random to noisy
> pick ee4626e added snes ex56, Plex with 3D linear elasticity
> pick b79c9a7 added ex56 in snes, 3D linear elasticity using Plex on a cube
> pick a64eebe clean up cheby fix
> pick 23c3567 small cleanup of noisy cheby
> pick cc7a30b fix ex56 init/fin error
> pick c34fc5a remove spaces
> pick 0008a30 fix complex build
> pick e78b637 updated test for new cheby
> pick 4acf97d fixed test for new cheby
> pick fdcaa90 merge makefile changed for ex56 and parmetis
> pick f2cb842 fixed bug in makefile
> Satish
> On Wed, 25 May 2016, Mark Adams wrote:
> > I do git rebase -i master, and I get a lot of these:
> > 10:53 mark/snes-ex56c= ~/Codes/petsc/src/snes/examples/tutorials$ git
> > rebase -i master
> > error: could not apply 121daff... I am sick of finding examples that have
> > no test cases!
> > When you have resolved this problem, run "git rebase --continue".
> > If you prefer to skip this patch, run "git rebase --skip" instead.
> > To check out the original branch and stop rebasing, run "git rebase
> > --abort".
> > Could not apply 121daff3befe8860e39d0d85f21fecb925e5e5cd... I am sick of
> > finding examples that have no test cases!
> > I did this this morning and there were about 8 of these conflicts that I
> > had to fix manually. I wanted to check before I proceed. They were
> > straightforward fixes.
> > Mark
> > On Wed, May 25, 2016 at 10:40 AM, Mark Adams <mfadams at lbl.gov> wrote:
> > > On Wed, May 25, 2016 at 10:18 AM, Satish Balay <balay at mcs.anl.gov>
> > >> > 10:09 mark/snes-ex56c= ~/Codes/petsc/src/snes/examples/tutorials$
> git
> > >> reset
> > >> > --hard f2cb8422898d35ef96e146caa3a95b2f879b25f1
> > >> > HEAD is now at f2cb842 fixed bug in makefile
> > >> > OK, now what?
> > >> 1. Verify that its feature complete as you expect [and not missing any
> > >> commits]?
> > >> gitk master..mark/snes-ex56c
> > > I got this error:
> > > 10:37 mark/snes-ex56c= ~/Codes/petsc/src/snes/examples/tutorials$ gitk
> > > Error in startup script: unknown color name "lime"
> > >     (processing "-fore" option)
> > >     invoked from within
> > > "$ctext tag conf m2 -fore [lindex $mergecolors 2]"
> > >     (procedure "makewindow" line 347)
> > >     invoked from within
> > > "makewindow"
> > >     (file "/Users/markadams/homebrew/bin/gitk" line 12434)
> > >> 2. Update branch as needed [perhaps you were wanting to squash
> > >> commits? since you've mentioned 'rebase -i' previously?]
> > > git rebase -i
> > > or
> > >> 3. verify and test locally?
> > >> 4. update 'mark/snes-ex56c' on server.
> > >> git push -f
> > >> 5. If feature complete - update pull request?
> > >> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160525/e47fa406/attachment.html>
