[petsc-dev] Dev Manual Blurb on PETSC_INTERN and PETSC_EXTERN ?
Patrick Sanan patrick.sanan at gmail.com
Tue May 24 03:52:24 CDT 2016
On Mon, May 23, 2016 at 07:49:43PM -0600, Jed Brown wrote:
> Thanks, Patrick.
> Patrick Sanan <patrick.sanan at gmail.com> writes:
> > A patch is attached (0001-..) which adds an entry to Section 2.2.
> This patch references KSP_Create which doesn't exist.
Thanks; I see you fixed this for me already! https://bitbucket.org/petsc/petsc/commits/24e59b323349d916852d32a8a3e4776e0940adc9?at=master
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20160524/7d1cb6a3/attachment.sig>
