[petsc-dev] config error
Thu May 19 20:59:04 CDT 2016
  Adrian,
   I should work now. We had some new code that had incorrect formatting for bfort but I think I fixed it.
   Thanks for reporting it so promptly I got the fixes in just before our nightly tests...
   Barry
> On May 19, 2016, at 8:38 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> hi
> I'm getting the following error when I try to run configure on the latest 'next' branch:
> acro018 at des108:~/software/PETSc/code$ ./configure --download-netcdf --download-exodusii --with-hdf5-dir=/usr --download-triangle --download-ptscotch --download-chaco
>             Configuring PETSc to compile on your system
> TESTING: checkSharedLibrary from config.packages.sowing(config/BuildSystem/config/package.py:731) *******************************************************************************
>         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> *******Error generating Fortran stubs: Error running bfort
> cd /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope; BFORT_CONFIG_PATH=/home/acro018/software/PETSc/code/lib/petsc/conf /home/acro018/software/PETSc/code/linux-gnu-c-opt/bin/bfort -dir /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/ftn-auto -mnative -ansi -nomsgs -noprofile -anyname -mapptr -mpi -shortargname -ferr -ptrprefix Petsc -ptr64 PETSC_USE_POINTER_CONVERSION -fcaps PETSC_HAVE_FORTRAN_CAPS -fuscore PETSC_HAVE_FORTRAN_UNDERSCORE -f90mod_skip_header -f90modfile f90module.f90 telescope.h telescope_dmda.c telescope.c
> Testing path as file /home/acro018/software/PETSc/code/lib/petsc/conf
> Testing file /home/acro018/software/PETSc/code/lib/petsc/conf/bfort-base.txt
> Testing file /home/acro018/software/PETSc/code/lib/petsc/conf/bfort-mpi.txt
> bfort terminating at 1033: Cannot append name to return type*******
> Any ideas?
> Cheers, Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 84611
