[petsc-dev] config error
Adrian Croucher a.croucher at auckland.ac.nz
Thu May 19 20:38:37 CDT 2016
hi
I'm getting the following error when I try to run configure on the
latest 'next' branch:
acro018 at des108:~/software/PETSc/code$ ./configure --download-netcdf
--download-exodusii --with-hdf5-dir=/usr --download-triangle
--download-ptscotch --download-chaco
              Configuring PETSc to compile on your system
TESTING: checkSharedLibrary from
config.packages.sowing(config/BuildSystem/config/package.py:731)
          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log
for details):
*******Error generating Fortran stubs: Error running bfort
cd /home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope;
BFORT_CONFIG_PATH=/home/acro018/software/PETSc/code/lib/petsc/conf
/home/acro018/software/PETSc/code/linux-gnu-c-opt/bin/bfort -dir
/home/acro018/software/PETSc/code/src/ksp/pc/impls/telescope/ftn-auto
-mnative -ansi -nomsgs -noprofile -anyname -mapptr -mpi -shortargname
-ferr -ptrprefix Petsc -ptr64 PETSC_USE_POINTER_CONVERSION -fcaps
PETSC_HAVE_FORTRAN_CAPS -fuscore PETSC_HAVE_FORTRAN_UNDERSCORE
-f90mod_skip_header -f90modfile f90module.f90 telescope.h
telescope_dmda.c telescope.c
Testing path as file /home/acro018/software/PETSc/code/lib/petsc/conf
Testing file /home/acro018/software/PETSc/code/lib/petsc/conf/bfort-base.txt
Testing file /home/acro018/software/PETSc/code/lib/petsc/conf/bfort-mpi.txt
bfort terminating at 1033: Cannot append name to return type*******
Any ideas?
Cheers, Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 84611
